'31 Coupe/Michigan
New member
I replaced my 6-volt battery today after the old Die Hard finally died after 7 years. When I took the coupe out for a test run to make sure everything was working properly, all of a sudden, my horn started blowing erratically. If I went over a bump or turned a corner, the horn would keep blowing and I had to keep tapping the horn button or turn the light switch to make it stop.
Has anyone had this problem, or can give me a tip on where to start looking??
Thanks,
Doug L.
Thanks,
Doug L.
