john charlton
I have a bunch of "dead" rods no continuity end to end . I thought to see if I could easily make a repair .This is how I did it . This was on 30/31 unit . I lifted the tabs and tapped out hthe horn button keep ring . I unsoldered the bottom end and pulled the top contact and pulled the wire clear ,it was in good condition . I used a Dremel to grind the top contact flat and with a small punch tapped it out of the black phenolic housing . I clipped the brass contact off and pared the wire back so I had a 1/8" wire end bare . I tinned the wire end and neatly soldered a short wire to it which I also tinned . I tinned a small brass washer and pushed the wire end through the housing and soldered the union . The housing is fairly heat resistant so minimal deformation . Pushed the wire down the tube and resoldered the washer on the end . Put back in my 28 phaeton and my AE horn blows mighty fine !!!
John in Suffolk County England .
