Horn hookup
biggieou
Hi,
I just picked up a Sparton horn for my car and was curious what connectors I need to use to get juice to it? My car had bullets on the end of the wires for the old horn.
Sent from my SM-N920V using Tapatalk
My Sparton horn uses bullets as well.
So do the bullets just side under those metal tabs at the bottom?
Bob's picture is correct. They just slide under the tabs with the end of the bullets facing the center screw. That way they are less likely to pull out of the hole on the horn cover.
