Kevin - Illinois
This is embarrassing, but I can not figure out how to connect my horn on my 53 Mainline. The car is 12 volt negative ground, otherwise stock. The car was completely rewired before I bought it, but no accommodations were made for the horn. There is a wire that comes out of the steering column. How can I connect a relay to this and make the horn work with the steering column. I currently have a small push button under the dash and the horn works fine...
