31Tudor is correct. Also, the mounting bracket and the bug screen were raven finished as well.
These items were not painted and should not be today.
Hope all of this information is a big help to you.
Regards,
Neil Stegall
THE HORN MAN
601-469-0878
Thanks for all the good info.
Would flat black paint be like a raven finish ? (not worried about judging !!!)
Jon in Ohio
Jon in Ohio
I found G-96 gun blueing works well.
Regards,
Neil Stegall
THE HORN MAN
601-469-0878
The following details apply to all horns:
The horn including the inside of the projector
assembly (bell), and mounting bracket were,
dipped in gloss black enamel prior to assembly.
The steel screw and lock washer holding the motor
cover were unpainted, blued or cadmium plated.
The tone adjustment screw was blued or cadmium plated.
Rim bolts and nuts were raven finished. Only the bracket bolts
had lock washers which were raven or unfinished.
Neil,
Where does this information come from? The 2011 revisions of the RG&JS does not address this.
Regards,
Neil Stegall
THE HORN MAN
601-469-0878
