I had the same happen, the horn spring contact in the middle of the wiring harness contact plate wobbled a bit ,( or, with repro parts, the hole in the upper switch rotating plate is smaller), and shorted out on the upper switch.plate. I cut a piece of shrink tubing the length of the spring contact and shrunk it over the spring so only the very end of the horn contact is clear.
