Before I wrote the current engine off and ordered one, I wanted to look at the babbitt and see whether it was salvageable. My thought was that I could get the block machined locally and not have to send it off if the babbitt was still good. I wasn't optimistic given the condition of the deck and the interesting safety wire job on the rod caps, but I was surprised with what I found.
The engine has been running for the last 10 years until recently. The engine damage I discovered since taking the head off appears to have been from water sitting in the cylinders and block for many months until a repair was attempted. My guess based on the engine's appearance 10 years ago was that it was at least 10 years since it's last rebuild then. The babbitt then is probably 20+ years old.
The only main I pulled was the middle which appears to wear more than the others from everything I've read on here. The crank shows damage (2nd and 3rd pics) from having the water sit on it and the damage matches the groove pattern from the bearing material. Despite this pitting the rest of the surface is perfectly smooth and it ran this way for 10 years that I know of and does not appear to have noticeably damaged the babbitt in the main cap.
My question is can I continue using this babbitt, replace the shims, and rebuild the rest of the engine? It looks a lot better than some of the used babbitt bearing photos I see out here.
