fredski Senior Member Jul 14, 2015 #1 Below hood clips and hood handle there is single hole Below these and wondering why they are there. Fredski
fredski Senior Member Jul 14, 2015 #3 Kevin in NJ said: Rubber bumpers were riveted there. Click to expand... Where the holes are just below handles and hood clips there is not , Anything under the hood to make rubber bumpers to make contact with. Fred
1955cj5 Well-known member Jul 14, 2015 #4 The bumpers go outside of the hood, and the latch presses against it.. There is also supposed to be one mounted to the body in the center of the hood opening, it would be on the inside when the hood is closed.. Attachments P1080354.JPG 106 KB · Views: 52 P1080569.JPG 167.1 KB · Views: 54 P1080570.JPG 92.1 KB · Views: 50
fredski Senior Member Jul 16, 2015 #5 1955cj5 said: The bumpers go outside of the hood, and the latch presses against it.. There is also supposed to be one mounted to the body in the center of the hood opening, it would be on the inside when the hood is closed.. Click to expand... Thank you , now I understand seeing pictures. Wonder if most model a ers Use these bumpers or remove them ? Fred
1955cj5 Well-known member Jul 16, 2015 #6 I like them...they keep the latches snug and they keep the hood from rubbing on the latches and vise versa...
