Howdy,
I am having some difficulty aligning the hood on my 1931 Model A pickup after doing a frame up restoration. The problem is that the rear hood hinge retainer needs about 1/8 an inch more space between it and the cowl band in order to align with its mounting screws.
I have used up all the adjustment in the radiator rods moving the radiator away from the cowl and still not enough space. The radiator now is leaning slightly forward at the top. I believe the mounting holes of the radiator are slotted with which I could straighten up the radiator but still would not have enough room for the hood hinge retainer.
I have considered grinding the hinge pin 1/8" shorter but still about 1/8 inch is needed to have a margin along the front and rear edge of the hood to the cowl an radiator shroud.
The hood is brand new and measures the same as the old hood. The hood lines up quite well with the cowl and the radiator shroud that have new lacing. The problem is with clearance for the retainer.
I measured the distance between the front face of the cowl just above the first cab mounting bolt with the doughnut shims to the near side of the hole in the frame for the hood bumper. The measurement on both sides is 11 3/8 inches. If I jack the cab back toward the box, would I gain another 1/16" or would shimming under the cab bring the cowl up and gain the required distance? Maybe I should place a framing square on the frame to determine if the cab is at 90 degrees to the frame or isn't this required.
This Model A has been in the family since 1931. I used the original wood blocks with new bolts and new shims of an equal amount to the old at the exact same places. The frame is not bent at the motor mounts.
Is there any book or manual with any dimensions or checking procedure for the correct installation of the cab? Does any one have any suggestions?
Thanks,
Maury
Thanks,
Maury
