Hood adjustments 1941
Doughie
For those that need to know. If your homeood sits high at cowel. Loosen two bolts under hood that hold the hinge in place and one inside above kick panel.Gently pry the hinge up. Mine only moved about 1/16 inch. Hood sucks right down tight to the cowel! So simple but frustrating if you don't know. CHEERS!
