Phil Senior Member Sep 18, 2010 #1 I just looked at a 28 A with a honey comb radiator. When did Henry stop using the honey comb? Thanks, Phil
Jack Richard Junior Member Sep 18, 2010 #2 Ford did not use honeycomb radiators on the Model A. There were honeycomb radiators available on the aftermarket, that must be where it came from.
Special Coupe Frank Well-known member Sep 18, 2010 #3 Ford always used a "fin & tube" radiator, going back as far as the Model A of 1903...
Phil Senior Member Sep 18, 2010 #4 Thanks guys--knew I had never seen one--thought it might have been AR. Phil
28RPU Senior Member Sep 18, 2010 #5 I once had a 1928 Chevy that had a honey comb radiator.Maybe it was a Chevy.
Special Coupe Frank Well-known member Sep 19, 2010 #6 Chrysler Corp used cellular ("honeycomb") radiators into the late 1940's... and I'm pretty sure Dad's '30 Chevy has a honeycomb as well. They are quiter a bit heavier than a fin & tube radiator of the same physical dimensions...
Rowdy BANNED Sep 19, 2010 #7 I had a 30-31 honeycomb A radiator last year. Traded it for nice left rear fender for the delivery at Chickashae. Both of us were very happy with the trade, so it worked out well. Rod
