Holley NH Thread size
Preacher
can't locate a printed thread size for a Holley NH drain valve assembly (center drain). i need to repair the female thread in the mixing chamber. anyone have this info or know where to look? the OD on the drain valve measures .553" approx 24 tpi. could this be a 14mm thread?
Spray nozzle is easy. It is 3/8 24 UNF. The drain valve is a little more difficult. It is 9/16 24 UNEF. If you need to retap the needle valve threads, they are 1/4 32 UNEF.
mtfca website. All of the info is there.
To search type this in your browsers search box with no quotes, "nh threadsize site:mtfca.com"
The nh threadsize can be substituted for whatever you are looking for and the website after site: can be substituted for where you want to look.
Thanks loads! Turned a Stainless S threaded bushing, then bored the carb, epoxied in place. IMG_20120527_143818.jpg
