Burt Lake Barn Member Apr 1, 2020 #1 I am looking for a source for the vacuum port plug that fits the Holley 94 carb. It appears to be an odd size / thread type. Any one have any info that might help me locate them?
flatheadmurre Well-known member Apr 1, 2020 #2 SAE 45degree flare plug fits there...Eaton has them or any major supplier of brass fittings. Thread is UNF if i got it right so not exotic...
tubman Well-known member Apr 2, 2020 #5 When I had to plug them, I always used a "Ford Nut" soldered up. Are you telling me a 3/8-24 set screw would have saved those rare pieces?
scicala Well-known member Apr 2, 2020 #6 I've cut off the end of a 3/8"-24 bolt before and then cut a screw drive slot/filed it flat, instead of using a brass original soldered shut. Sal
Burt Lake Barn Member Apr 5, 2020 #8 Answer to my last question was no based on small amount of vacuum being plugged.
