Holley 94 throttle shaft
3twinridges
I have a new Holley 94 throttle shaft. Fits really nicely in the throttle bore with zero play. The lever needs to be peened onto the shaft end. How would be the best way to do this without damaging or bending the brass shaft?
JB
I would think a vise with soft jaws(rubber around the new shaft) and as close to the lever as possible would work. Then a drift to peen the brass lever end down. Help me guys, where's CharlieNY to chime in. Be patient more experienced help is on the way.
Thanks Gary, originals seem to have a deeper hole drilled in the end for a better mushroom. I was thinking the same on the vise with an air hammer. Figured somebody on here has done this with good results.
JB
Jack's got it.....I use a 6 - 32 BUTTON head allen screw. If you go this way it is best to
grab the shaft in a lathe to drill the hole before tapping. The manufacturer fixtured
everything and smacked the end of the shaft HARD. This operation rolled the brass over
but most importantly caused the brass to bulge out against the 'hole' in the arm.
I just reread your post....if you have an air hammer and soft jaws in a good vise that might work too.
Charlie ny
cas5845@yahoo.com
716 440 8952
Thank you Charlie. I annealed the end of the shaft and have a few air hammer bits that I think will work. The vise part is what concerns me, I do not want to oblong it with too much tension. I will play with it a little tonight and report back.
JB
I would think , Clean both sides of the Plate on a small wire wheel and the Brass shaft and Sweat Solder the shaft in place, both sides, it can always be reheated and moved if desired at any time , nothing will get damaged MHOpinion .. R:)
Whatever you do, do not hammer on the end of the shaft without it being completely supported inside another tube with very little clearance. I started tapping on the end of one of mine while I held in in a vice, and it promptly collapsed like a pretzel.
I second this. The "slots" in the shaft for the butterflies make it very weak.
I plated out the accelerator lever this morning. I chucked the shaft up in a vise with two oak pieces and slowly peened out the shaft with a trim hammer. I worked back and forth on peening it and expanding it with drift hits to the drilled hole. It turned out ok and tight. Doesn’t look factory but close.
My black oxide kit should be here Monday and I can dip the base and complete the carb assembly. Thanks for the help guys, much appreciated!
JB
JB
Did you anneal brass by getting hot and dropping in cold water . Doing it like steel will do nothing .
Never mind , i see its already done
Yes that is how I did it and it was still hard as rock LOL! I didn’t get it as hot as I normally would, I was afraid of annealing too far down the shaft and causing early shaft wear.
JB
