Yes, JB, Caswell is great. Yes , some of the hardware should have been cadmium, some prolly bare. With MH, who knows? Frankly Im not too concerned. Im rebuilding this MH for me. I try to re-use original fasteners, and don’t like painting what wasn’t painted
Fram oil filter for my CJ2A, parking brake for same, all of the hardware in brake assembly was rust and grease. Re-lined the original shoes.
Other park brake pieces are from a 2wd F3 (my parts pickup), one one right is from the MH. The thumb buttons I nickel plated.
the carburetor base, which is from a mid-50s GMC, was blasted, then cold gun-blued. Once dry, I smear motor oil infused beeswax onto surface. That is followed by a light buffing.
The last picture shows the transfer case torque arm and bracket; the transfer case low range lockout linkage and bronze brackets, bushings added to take out wear, and new plated shaft I made(brackets had traces of black paint, but cant bring myself to paint them. DIY rubber axle snubbers, as originals were petrified, as were the original wood spacer blocks. Had to reshape hardware store carriage bolt heads to match originals, then plated them.
