holley 94 question
rcranger
have a eab motor in my T ,carb is running way to rich what is the best kit and how do i figure which power vale to use ,wrote to couple guys on here who know these questions but never recieved any answers, getting ready for a trip and want to get my mpg up from 18 to in the 20's
A kit will help you with a rebuild if there is a carb problem, but won't help an improper jetting issue. Do you know what jets are in it? Or to high fuel pressure or improper float setting, etc.
You have to lower your power valve if you have a cam. The longer the duration the lower you go. If it's a stock motor use a stock power valve
To answer your question, the best kits come from Daytona Parts. You can't order on-line from them; you need to call them and talk to them so they can make sure you get the right kit.
I have done a few 94's over the last few years, and most of the problems I found concerned ill-fitting or improper power valves. The later model ones for Holley 4-bbls will screw into the carb body, but will leak and cause all kinds of problems. I even ran into a case where a power valve was too high and pressed against the carb base and wouldn't work at all.
An often overlooked cause of rich running is the flatness of the base and body. If they are not properly flat, you can get an air leak into the power valve chamber, which can lower the vacuum in the chamber and cause the power valve to be supplying extra fuel all the time. Lapping the lower face of the body and the upper face of the base will get them flat. Mine were miles off and the carbs became much more tuneable since I did get them flat.
Mart.
For proper fitting power valves try CarQuest. I believe part number FM728G is the 5.5 and it comes with a gasket. Just picked one up yesterday.
18MPG is pretty good for a flathead. Fuel economy depends allot on the driver as well as the carb. You need to install an AF meter and take it for a drive. Also the ignition system must be able to advance the timing during cruise to be able to burn a lean mixture when the PV is closed.
But at 18 mpg I think it's very close right now.
