JRN1967
I've got an 8ba with stock dist. and a single Holley 94. The distributor has new points, cap, condenser, 12v coil, new resistor wired in series. New plugs and wires. Copper vacuum line is tight from carb to dist.
Holley 94 has a new kit from Daytona Parts, installed by me. The power valve is a 5.5 and is supposed to be the one that has the flat surface so it doesn't leak. Float is set to 1-3/8". Jets are #51. Throttle shaft isn't loose. New base gasket.
New gas, new tank, & new gas lines.
Timing is set with a light to the bump on the crank pulley. But the pulley is from the wide belt truck and the cover is from a 1950 car. Not sure if this cover pointer is right for the truck style pulley?
This is in my 31 coupe project.
When I try to start the engine it catches right away. If I feather the throttle I can keep it running, and if I do that for a while I can keep it running barely on its own with the idle screw maxed out, but the rpms's are very low. Seems like all the cylinders are firing. But it hesitates if I goose it.
If I turn my idle air screws in it will stall, which tells me its not a vacuum leak issue.
Any idea why I need to have the idle screw maxed just to keep it running?
