Hi guys,
Here is the deal(ordeal) I just found.
Started new motor with freshly rebuilt 94. New throttle shaft(reamed in place) , new plates, new gaskets etc. the works.
Throttle plates are centered in the bores , everything is nice and tight
BUT right side bore is dripping fuel at idle from atomizer , so it must draw fuel through main jet , but how, because plates are not even close to the transition
holes...
So , I´m confused . If somebody has an idea please educate me.
Thank you.
holes...
Thank you.
