Holley 94 carb. Float adjustment Q...
40Pickup
Got this adjustment data with my carburetor kit. Is this correct?
Not much needle movement.
Grateful for the help!
Jorgen
If you have set the float at those spec it should be fine. Your engine is not going to burn gas fast to out run the gas going through that needle and seat. Walt
Thanks, Walt.
There is a big difference between the spec for Model AA-1, 2100 and Model 2110. So it confused me!
Jorgen
