Panheadguy
Top of the carb is off. Bottom on the bench with float chamber full of fuel. The link is in the hole for the most squirt.
Almost nothing is squirting out. I am operating the throttle through full travel so the pump plunger is coming to the top. The check ball and (pump) inlet needle are free. squirting carb cleaner through the passages confirms no internal blockage.
This all after I decided that I probably needed new pumps due to age and they seemed sloppy in the cylinder. I bought new pump plungers from Charley Price.
I'm at a loss.....I thought I knew all about these carbs but now not so sure. Ideas anyone?
