smtichy
Hi fellow Ford fans,
I'm looking for someone who has actual experience with this, specifically trying to straighten a warped main body cover (fuel bowl cover) on a Holley 4000 teapot.
Yesterday I did a rebuild on a friends Holley 4000, and when putting it back together noticed the top gasket wasn't a tight seal. I put the cover on a flat surface and could see that on the passenger side of the carburetor (opposite accelerator pump side), at the center point between the two screws I could see the cover was warped upward about 1mm.
Question: I'm considering trying to put the cover in a vice or similar to try and flatten it out, but am concerned it may just crack it. Has anyone tried to do this on an Holley 4000? If so did it work? For now I just drew a bead of sealant around the outside edge of the cover, but know this won't stop any gaps between the various vacuum passages toward the center of the cover. Another thought I had was to stack 2 cover gaskets on top of each other to
FYI - The cause of the warping seems that in the past someone had stripped the air-cleaner anchor screw threading inside the main body, so they put a new threaded brass insert in the cover (instead of the body), drove a bolt through that, bottomed it out, putting upward pressure in the middle of the cover, thus creating a slight dome.
On one hand sorry if anyone's had this experience, but glad for their 1st hand know how on sorting it out.
