My Old Blue
Hello fellow Ford owners. New member here. Working on my 4000 4bbl and rebuilding it. I see conflicting information on whether the red nylon check ball is used in the distributor vacuum passage port located on bottom of the base.
Mike's Carb parts says it's used with no stipulations, whereas Daytona's install sheet says it is used on standard trans models. I have a Fordomatic in my 56 Country Sedan. Any info is appreciated.
