Diavolo
Howdy!
So, I acquired a Holley 2300 that I rebuilt with 61 jets, replaced the 2 stage power valve with a single stage, installed a manual choke kit and put it on my 55 F600 with a 360.
It won't idle for diddly squat. I tried bench setting the idle mixture screws, and it would hardly idle. After turning the screws in all the way it FINALLY idled somewhat normally but it's clear that the mixture is extremely lean. I could barely drive it into the garage to work on it - I had to flutter the gas and clutch to get it in the door.
Any ideas what I should do to solve this little problem? I had a autolite 2bbl on it before and it was flooding and I actually prefer holley. If I can't get it to work, I might just put a pressure regulator on the autolite but I would rather not.
Thanks in advance.
Thanks in advance.
