Jalopy Tin
I would like to know how much gap there is between the hogs head and the block when everything is bolted together, without the felt gasket. Can i use a bead/string with "the right stuff" instead of the original felt? Will it fill up the gap? All the bolt holes in pan and cover line up perfectly.
I bolted them together today but was unsure if the bead was enough. I would like to do it the right way before i put the engine back.
Second, is there some way to adjust the transmission bands - pedal play for clutch, reverse and low/high with the engine out of car or do i have to put it in the car and use the floorboard as a reference?
/Tom
/Tom
