Hobart Simplified V860 Welder ???
Ohio1950
Hey hows it going? I have ran across a Hobart Simplified Arc Welder that has a Ford V8 60 on it which operates the welder. I cant find a whole lot on these. It has a very cool looking Hobart Radiator Shroud/Radiator, The motor turns over free and isnt locked up. Wondering if there is any demand for these and what something like this is worth.
Thanks
Dan
I can't give you any background on the 60hp Hobart welder, but I recently had one (couple years ago). Your perspective may be to preserve it as a unique piece of welder history. I bought mine for the 60hp engine which happened to be the more desirable 1940 60 hp, I scrapped the rest. If you would like to know how to ID a 1940 60 from the 1937,1938 1939 let me know. Although all 60hp engines have a following, most are sought after as a static display for the garage or living room and midget race cars. NOS
Hey hows it going? Yes i would def be interested in knowing how to tell the 40 Engine vs the 37-39. I appreciate all the information on it.
Thanks
One of the easiest ways to tell if a 60hp is a 1940 compared to 1937 through 1939 is the intake manifold will have the oil fill pipe at the back of the intake. The earlier 60hp engines 1937-1939 had a cast round stub in the left side of the bellhousing for the oil fill pipe, roughly 1 1/2 to 2 in diameter, I'm not near an engine to measure. The 1940 block does not have this oil fill stub in the bellhousing. The 1940 block is the most popular among midget racers. The early 1937 engine had what is commonly referred to as the "tin side" engine block, which is actually stainless steel sides machine welded to the block. Others who may be more qualified with the 60hp engine may be able to give you other ques. Intake manifolds can be interchanged on any of the engines so look at the bellhousing. The front engine support to the frame is often found broken, not a serious problem as it unbolts, but costs to replace. Values can range from $300 for non runners to $1,500 for a running 1940 non rebuilt. Value also depends on how complete (capable of running) and not a field piece frozen solid.
