well they are bolted to the frame on this lil speedster, so I know they are grounded
There's only 2 or 3 things that could cause this!!! Keep it SIMPLE!no headlights high or low on a 31 coup/ speedster tail lights work. the wireing harness is / was new a couple years ago. everything worked fine. ive done a quick look but see hnothing wrong. I have tail lights. brake lights
Bad ground at the battery end can do that too.Have you checked the bulbs ----I had a customer with modern car come in, he is electrical engineer, no headlights ---he said must be bad switch---I said lets check bulbs---"it can't be bulbs"----2 bulbs later they were working
