Well, I got the door off today. ('32 tudor) I was amazed how soft the pins are! I wound up using an air chisel with a flat point, PB Blaster, heat (lots) and a drill. One of the problems was that the pin rotates with the door and develops a wear pattern where it passes through the body portion of the hinge. Sometimes, I was able to move the pin about 3/8" and have it hang up where the step on the OD would hang up going into the next portion. Driving with either the air chisel or hammer and punch seemed to be upsetting the pin like a rivet making it a tighter fit in the hole. AARGGHHH!! Now, I have to figure out rebuilding the bottom of the door.
