I found that the double bolt tool worked better also.
Note: as 5Window said the pins in my coupe were 15/64ths inch (standard size I think).
The tool I used had bent pins when I got it. I made some 1/4 inch diameter ones of correct length and of course they were a 1/16 too large, which made the removal job harder than it had to be. But by drilling and the using the tool I finally got the pins out.
If you decide to make pins ... mild steel is your friend, hardened steel may shatter under the pressure or from hammering on the tool.
The oversize pins that I found were 1/4 inch.
I like the idea to move the door around.
I purchased a C style tool from Bob Drake. Very well made, but didn't work that well. I have used to two bar clamp-that works a bit better, but not great. LOTS of soaking with PB Blaster,etc. is the place to start. It may be difficult to access the hinge pins to drill without hitting the drip rail,etc. Keep in mind the following:
The knurled part of the pin under the top lip has been happily rusting in place for many years.
The pin size is NOT 1/4", don't overdrill the hole, although oversized pins are available.
Replacement hinges are really really expensive-think before you grab a bigger hammer.
Sometimes heat can be your friend, sometimes the "blue wrench" is not a good idea.
The BEST tip I got was from Bill at the Model A Acres in Watsontown,PA. He showed me how, with time, the hinge pin can have a groove or notch cut into it by the hinge. In the wrong position, it will never come out because you cannot hammer the hinge with the groove wedged against the hinge body. Try turning the door to different positions and eventually you position it so that the notch doesn't like up with the hinge and you can drive the pin. This was the ultimate answer for me.
