Standard size hinge pins should fit fine as the hinges wear over the years. Oversized pins are available at parts supplier, but what happens is the part of the hinge that is stationary doesn't enlarge where the hinge part that rotates on the pin gets enlarged. So if you use oversize pins, they will probably fit the worn part, but not the stationary part. Unless the hinges are really worn (like maybe the driver side door), standard pins should work OK. Hope this helps.
