The Master Cylinder
I was wrong.
I sincerely doubt that!! BTW Jim. Is your book back in print? If so where can I obtain one. PM me if you don't want to publish your address.
I was wrong.
there seems to be considerable disagreement on the use of a 6v starter in a 12v conversion.
I converted the system and retained my 6V starter. on start the impact was so severe I'd wince. Twice I broke the starter shaft and good ol Synchro modified it for me. If I'd had left it broken shafts would have continued and maybe something else as well.
The math on using a 6 volt starter driven by 12 volts multiplies the torque by 4X! that is 4 times the torque driving the bendix gear into the ring gear. Eventually, the bendix will give or the ring gear teeth may take the brunt, but it will work for a long time. The actual starter motor will do fine, it can handle double voltage and current just fine.
