Old Redneck
On my 56 T-Bird with Power Steering how much trouble is it to install the High Output Water Pump? Any of you fellows done this? Did it help overheating at low speeds?
Go to the COOLANT SECTION in your SHOP MANUAL and it will give a DIAGNOSTIC SEQUENCE to find the cause of no heat. Easiest way out.I got a 170 thermostat to install. So far the heater blows cold air no heat?
The heater controls are usually vacuum operated with a valve on the side of the heater box above the left foot of the passenger. There may also be a vacuum operated water control valve on the front of the intake manifold just above the thermostat. The new/replacement valves are made 'off-shore', they are pricey and tend to leak or fail quickly.. . . I got a 170 thermostat to install. So far the heater blows cold air no heat? I an also installing a Radiator Overflow Tank because when I got home the Radiator was a little low. Thanks for the information and that a big help.
The "Knowledge Base" link on that page opens another document with water flow tests and graphs.
the T-Bird water pump spacer is still necessary, quoted from the High Output Water Pump page... (bold added)
"The pump only fits on Thunderbird engines. They can be identified by the 1" or so spacer that is situated between the water pump and the timing chain cover. It is the extra room created by the spacer that this pump exploits with extra fins on the back of the water pump impeller."
