high oil pressure?
derek costello
While giving my engine a compression test (120lbs on all, after valve job) ,I noticed my newly installed mechanical oil pressure gage read 90psi ! the electronic gage in the car only goes to max 80psi, all of a sudden it dropped to 65lbs and maintained that while on the starter.
So I think my oil pressure relief valve must have been stuck because every time I crank it now it reads 65psi.
So, my question is how much do these little flathead oil pumps put out??
The new production Melling pumps will put out 80 PSI I have found the standard replacement M-19 and the high volume M-15 both have the same pressure relief spring. Testing each of these pumps on my test stand have shown this pressure. The original design Melling high volume pump produced in the last century the M-21 will produce 100 PSI at the same RPM testing i do with the above pumps.
Ronnieroadster
The oil pump is driven by gears on the cam. The cam turns at half the rpms of the crankshaft.
Is it one to one off the cam with the idler gear. Just wonder with testing one on a test stand what range is considered correct to show its bill of health. High and low
It takes a noticeable difference in gear size to make much of a change in gear ratios, think ring and pinion gears or the crank gear versus the cam gear. It is about tooth count on the drive gear vs the driven gear. It is difficult to get much of a difference in tooth count without a corresponding change in the relative size of the gears. I really don't know what the tooth count is on the gears and there is an idler gear between them, but just looking at them it looks like it would be close to 1 to 1 between the camshaft and the oil pump.
What rpm does a flathead oil pump turn at ? Half speed of the engine?
During my testing to figure things out I find the oil pump is turning 1/2 engine speed by the idler ratio. It takes a lot of torque to turn the pump 3000 RPM using 10/30 weight oil.
An oilpump can take 2.5-5% of an engines power so it takes some power to drive it full out.
Eco engines now run variable oilpumps.
Ronnie. what is the length of the pump relief spring (standard ford pump)
When I take mine apart I want to check the spring and maybe replace it ?..thanks
Look in the Ford service books, it gives the poundage and at what length compressed of the spring.
Let me know if you cant find it, those pages are still open on my workshop desk.
Lawrie
