Tom Endy
Many of you may be aware that most every supplier in the country is out of stock of Snyder 5.5 high compression heads. I checked with most of the better suppliers and I am hearing several month before new stock will be available. One engine builder in Illinois I spoke with was very disenchanted as he is not able to deliver a number of engines he has orders for and it is affecting his cash flow.
I have been told there is an old article around written by the secrets of speed folks that was written before high compression heads became a marketable item, that says you can take a stock head and mill off 5\32", and if you have a 60 over bore you will have close to a 5.5 head.
My question is: How do you tell if a head has ever been milled? There must be a measurement of the distance from the bottom of the head to the distributor boss for a stock unmolested head. Does anybody know what that measurement would be, and is the machined surface of the distributor boss a contstant measurement?
Tom Endy
Tom Endy
