D dustyp489 Member Dec 6, 2011 #21 CarlG: ARP studs #AP3 -750-1SB are the shorter # AP5 -750-1SB are the ones for the water neck Their studs are rated 200,000 psi, which is higher then Grade 8 150,000 psi Person I called at ARP was Kammy Echiribel 805-339-2200 Great to deal with
CarlG Well-known member Dec 6, 2011 #22 dustyp489 said: CarlG: ARP studs #AP3 -750-1SB are the shorter # AP5 -750-1SB are the ones for the water neck Their studs are rated 200,000 psi, which is higher then Grade 8 150,000 psi Person I called at ARP was Kammy Echiribel 805-339-2200 Great to deal with Click to expand... Thanks Dusty, Is there another # for the #8 stud?
