High compression head
bettlesr
Are Tod's new iron 7:1 Winfield heads available anywhere or does anyone know when they will be?
Thanks
I will be casting some as soon as I run B heads. I have at least a dozen to cast. They are more like 6:1. The iron Thomas are 7:1.
Tod
Picked up some intakes last night when I dropped off the mold sand for the next aluminum 5 main Model A engine block. We are planning to pour the aluminum block Saturday 2/22. This week should also see iron B heads, Winfields, and a sample 3 main iron block poured as well.
Tod
id jump on the bandwagon except I just spent a whole bunch on this B project last week. it will have to wait for me
For those spectating, here is a great post I found that tests multiple combinations of HC heads, intake modifications, and plugs. Tests include a Thomas 7:1.
http://www.rarecarrelics.com/tests-the-ford-model-a-ford-engine.php
Bottom line seems to be that HC heads produce significantly improved performance by themselves at low RPM, up to about 1500-2000. That makes them a good investment for better performance in stop-and-go traffic. Once you get past that, other limiting factors become dominant, most prominently the intake and exhaust constraints.
Hi Tod. Do you have any picture that can be posted of both the Thomas and Winfield exterior configurations? I am curious about the looks of each one. Thanks, Steve
Thomas head.
Winfield original chamber. I also make this with a Weiand crow foot chamber, and the Winfield crow foot. Iron or aluminum on this and the Thomas. Aluminum Thomas is only available from Snyder, unless there is a flaw, in which case I can sell discounted as a blem.
Tod
