What is the best gasket to use for the Snyders 5.5 to 1 or the Snyders 6 to 1 head? Looking at getting one or the other and know this was discussed but don't remember which gaskets work the best.
Snyders, recommends the premium, silicone coated B gasket for their 5.5 and 6.0 high compression heads. Snyders part number for this gasket is B-6051-M. If the engine is bored way out you may have to use the copper clad 7013-C as this is a big bore gasket that will work with bores of one hundred and twenty five thousants and over
