Old Henry
My only nagging mechanical problem on my road trip a week ago was, after driving in the rain for a while at night, my high beam headlights stuck on such that, when I pushed the floor switch to change to low beam, the low beams came on but the high beams also stayed on. So, both were on. Pretty annoying.
I've had this problem sporadically for about a year when it's wet. I replaced the floor switch thinking the original that was still in there had gone bad but I got the same problem with the new one plus it was much stiffer to push so I put the old one back in. I checked the wiring coming off of the switch. The insulation was pretty bad on it so I wrapped all of the bare wire with tape back to good healthy insulation. Still had the problem last weekend.
My thought is, how to waterproof the switch and wires coming out of it and wonder if there is some kind of heat shrink wrap large enough to fit over the entire switch, terminals, and wire for a few inches that would shrink enough to tighten around all of it to water proof it. If anyone knows of any or has other ideas please let me know.
