If you can not close off the GAV then your jet sizes are not correct. I live at 3500' elevation and am able to close off the GAV without any resulting problem. With normal steady driving, by shutting off the GAV will result in better gas mileage. I try to always use original jets; I size them by thousands; I do not flow test my jets. Using a torch tip cleaner set, I mic the smooth ends and come up with the following sizes: .021 for idle jets, .036 and .037 for compensator jets, .037 for main jets, and .038 or .039 for cap jets. The double venturi carbs call for a #18 (.036) compensator jet.
I have been rebuilding carburetors for 30 years, using the above method, and have not had any problems.
Others may disagree with me or have other ways to jet their carbs but this has worked for me.
Ron
