banjoQ
My 36' truck is a mixture of parts, having been put together in 51' with collected components. It sat for fifty years before I got to it and put it back on the road. Been running great until the old radiator sprung another leak. Took radiator out and only then got a good look at the water pumps.As you can see, they were pretty bad. I decided it would make sense to replace them at the same time. My concern is what i have read pertaining to the hidden bolt inside the pump. I have used some acid with a brush sparingly to remove the corrosion and now can see the bolt head and fit a socket onto it. I know to use a six sided socket and to tap the head with a brass drift. Currently soaking with PB Blaster. Are there any other precautions I can take to not break this bolt? Am I worrying too much? Not sure an impact wrench is such a good idea here. Any advise would be greatly appreciated as its too easy to make the wrong move and do more damage.
