Higher compression makes the plug require more volts to fire. The wider the gap the higher the volts required to fire. The higher the volts, the tougher it is on the coil. If you don't have a miss when flooring it going up a hill you should be fine.
I don't see where plug gap would have any effect on how clean the plug stays, as long as the plug doesn't missfire. Ford changed the plug gap a few times from .025" to .035" and I didn't notice any change trying different gaps. I'm just using the stock head and my well worn engine has 50# on each of the cylinders.
Modern cars have large gaps becasue they run leaner, and a leaner mixture is easier to ignite with a larger plug gap. Plus the modern cars have high energy ignition systems with probably at least twice the zap of the Model A.
