With all due respect, aren't you over-complicating this? With everything shut-off, there should be no electrical drains. The amperage requirements for bulbs will be directly proportionate to the candlepower of the bulb also factoring in the voltage of the bulb, ….therefore 'it is what it is'. The same applies to the Ignition Coil. Now you can easily test many of the components by removing the Negative (-) battery cable clamp from the battery and temporarily install a test light between the post and the terminal. If the system has a draw anywhere, the bulb in the test light will illuminate. If for example the ignition has a voltage leakage inside, chances are the test light bulb will be illuminated. The intensity of the illuminated bulb will generally indicate how severe the draw is. Therefore in reality, it does not matter the current draw of each component since most of the wiring harness manufacturers have already sized the wire correctly for you. Any accessories added to the circuit can generally be sized on a one-on-one basis.
