glennpm
Hi,
I have an original and repro light switch with a new harness. I cannot move the switch CCW enough to get it to the high beam position. Off is up, CW one click to park, and one click CCW are fine.
I am checking for continuity between the 4YR battery wire and the light wires; 1B (park), 8BR and 9BR (low beam) and 8BG and 7BG (high beam).
I have had this on and off many times today and can't figure out the problem. It seems like the switch itself doesn't swing a big enough arc to move the contacts to the high position. The light rod is not binding on the top or along the shaft and is very free to move without the switch bail mounted on the bottom.
Can someone help me figure this out please?
