Hi, my Pilot Woodie is built on a very late E71C registered in 1954 so it has rod operated rear brakes. Sometime in the distant past someone has converted the front brakes from hydraulic to cable and I'm trying to return it back to juice. I've got a set of brake rods, cross shaft and so on from a Pilot saloon but that has cable rear brakes. The trouble is there looks like there is something missing from the Woodie. The detailed arrangements of the rod from the pedal to the cross shaft differs from the very small diagram in the workshop manual.
So, has anyone, by any chance got a good photograph or diagram of the brake mechanism from the rod attached to the pedal to the master cylinder?
Thanks, John
Thanks, John
