Help with a section ID
johnc451
I picked up this Model A back half years ago and it has been in a corner-etc. Looking at it today I am thinking it is a cabriolet/sport coupe section rather than a roadster. Lock area looks high for a roadster and the contours do not match my roadster doors. I can make it work for me but am I right thinking a restorer might have a harder time finding this than a roadster section? Input appreciated. John 845-266-5304
I am having difficulty seeing the pictures in a decent size to identify your body but look over the top of the rear fender for a stamped bead which will tell you if 28/29 or 30/31.
As Brent stated, there appears to not be a bead over the fender well which indicates 1928-29. Also, it is definitely not roadster.
It fits (or did at one time) '28-29 Coupe, Sport Coupe, and Business Coupe. It is substantially different than a Roadster so used for anything other it's original application will just be "home made" and will look as such.
Looks like its the same as my business coupe. However, it appears that someone hacked off the door frame above the panel. Mine is a 1928.
Here is a side view of my car before I tore it down:
Ok, I'll attempt to be a little more clear. First, although the pics show very little it certainly appears there has been some serious cutting and scabbing going on so the usefulness toward any restoration is questionable. Better pics would shed some light.
Now, most folks don't realize that ALL four '28-29 Coupe types use the same body from the belt line down and forward. Although it would require some work you can literally take the roof sections and swap them among any of the four Coupe body types.
Marco----that is valuable information as so many of these bodies have been taken apart---sawmills, doodlebugs etc. Thanks again--John
