Chester Leighton
I'm getting ready to overhaul the rear axle in the 37 Pickup I got from my father. A little background on this. He had a 5 speed T-5 transmission put in it and an open driveshaft conversion before I got it. The truck had been converted to 1940 hydraulic drum brakes and a 1953 8BA engine installed before he got the truck. All that said, it still has a 4.44:1 rear end ratio. I don't know if the rear axle is 1937 or 1940 or if that even matters. I'm looking to put a set of 3.55 gears in the rear axle, replace the carrier bearings, thrust bearing, pinion bearing and outer axle seals. I've overhauled a model T rear end so I'm familiar with having to shim the axle housings to set the carrier bearing clearance and pinion gear lash. What I don't know is how do you know when you have the correct carrier bearing clearance? How do you know when you have the correct preload on the thrust bearing? Is there a book or some other info I can get that walks me through this? I've watched some U-Tube videos and they were helpful but didn't give me the detail I'm looking for. I also have a motors manual that I've read but again, doesn't go to the detail I need. Or, is there some where reputable near Lynchburg Va. that does this work?
