bbrust
When I wind the window regulator for the drivers door of my 1935 Fordor down, it, skips and then the crank wants to unwind. It looks like I need to buy a window regulator repair kit but I'm concerned about the 3 rivets that hold the regulator in place. If I drill out the rivets and repair/replace the regulator shaft, it looks like I'd only have access to replace one rivet. The other two rivets are behind one of the gears. I'm afraid that I'd open up a can of worms if I tried to remove the gear mechanisms. Has anyone used the regulator repair kit? Thanks, Bob
