bobbycoke
Hello ford barners just when you get comfortable..........Car overheated when it cooled down could not start it ........towed home.......let it sit a while and think about it's sins..........went out and checked the torque on head bolts......wow needed retorqeing .......I had an engine rebuild and ran though a few heat cycles and retoqued the head 3 times.......then went on a long ride and had the overheating problem......now retoqued it started fine ran ok.........but it needed water tried to fill the radiator but couldnot as the water was draining out the carberator down the splash pan............is it a blown head gasket or something worse!!!!!!!
