I am SixVolt and might have a remedy for your problem. I am hoping that the latch mechanism is the same as on my 37 Ford because mine had a similar problem last year.
The handle will turn but will not unlatch the trunk to open... there is a square shaft attached to the handle (approx.3/8”square), the shaft extends into some sheet metal bracing to secure it in place, and this is where the actual spring loaded latch piece is slipped onto the shaft. This latch piece has a square hole in the center,,, so,,,turn the handle and the shaft twist the latch pulling it up to release the trunk. Over time and use the square shaft gets rounded off on its corners and slips on the latch piece, then of course doesn’t move it to release the latch. So for me I had someone push closed on the trunk while at the same time I pulled out on the handle in order to get more of the more square part of the shaft to bite better on the latch piece (square hole). It worked, and now I have a new shaft.
Good luck with it.
