Help to id a rear drum
ltek128
New member
Currently have a 1930 ford coupe with a ford 9" rear . I have been trying to match up the rear druns , but no ine seems to be able to tell me what year and model they came from. I did not get a build sheet with the car but was able to track down the builder who built the car in 1992 . Unfortunately he cant remember where it came from . It is a 5/ 4 1/2 bolt patern , drum hight is 3 1/8 , brake pads are 1 7/8 in with , drum is 11" ID and 12 3/8 OD , the center circle is 2 7/8 , the drum bolt holes ar either 1/2 or 9/16 . The inside drum where the shoes contact are 2 1/8 . HELP.
Click on the rods and customs link and try there. While there are few people on the forums that might know, you will have better luck there. Most of the Model A section is dedicated to stock cars and some hop up stuff as done in the 30's. This section of Fordbarn is for questions to the editors about the site not car questions.
Photos are going to go a long way in helping ID what you have, post them if you can.
