Hi russcc,
Humble opinion:
1. You report it starts fine when cold.
2. Then, you report it warms up, runs badly, then it is a "no go":
a. Is it possible "no go" because of fuel starvation ???? or,
b. Is it possible "no go" because of "hot" coil or "hot" condenser malfunctioning ????
3. After it kills & "no go", immediately after, you report it starts right up again & runs fine.
4. Please look first at 2a., above fuel starvation ....... Why?
a. With an engine at full operating temperature, if it were a "hot" coil or "hot" condenser malfunctioning, & one re-started it "immediately", then the coil & condenser would not have enough time to cool off.
b. However, with fuel starvation, in just a few seconds the carburetor bowl could refill enough to run a few hundred feet.
5. First investigate the "real" debris blockage source upstream for fuel starvation, i. e., the fuel tank -- on Model A's, like water, gas never gravity flows uphill -- why continue to clean the carburetor incessantly when the debris is coming from the tank?
Just my 2 cents suggestion where to look first.
